Ok, your initial reaction is - from the plates hitting the clutch basket dummy! Well yes, when you pull in the clutch lever you get some higher frequency but lower noise level from there BUT I'm talking about when in neutral with the clutch lever left alone and the engine ticking over. Under these circumstances there is a different and heavier clanking noise which to many people (and a proportion of Ducatisti as well) is bordering on objectionable. If you stop your engine and rotate the clutch back and forth by hand you will hear the knocking noise coming from inside the engine casing and no way when doing this by hand are the clutch plates hitting the clutch basket since they are all clamped together by the springs. I've checked this on a couple of dry clutch Ducatis and the result is the same. So, if the main tick over clanking noise, which goes away when the clutch lever is pulled in, is inside the engine casing is it the primary gears rattling against each other and no amount of dosh spent on new plates/basket will get rid of this noise? Maybe, once these dry clutches have some miles on them the 2 bearings holding the larger of the primary gears and the clutch basket behind the clutch basket wears and increases the tooth/tooth clearance between the gears and this causes increased clanking noises? Or, is it gear/gear clearance clanking in the gearbox which goes away when the clutch lever is pulled in with the engine running by reducing the engine pulses transmitted into the gear box? Can the clanking noise be reduced by changing the bearing behind the clutch? I don't have hands-on knowledge of the recent Ducati wet clutches or a workshop manual for them to see how their design/construction has been changed but they are quieter, but it can't just be the oil on the clutch because on dry clutches the noise comes from inside the casing behind the clutch. Anyone any thoughts on this? P.S. This is a technical topic and is not intended to start the 'love or hate the clutch noise debate'
Alan, firstly, what bike are we talking about ? Many older Ducatis had a steel clutch basket and steel plates......and they make an ALMIGHTY racket when they are worn, whatever the position of the clutch lever. There is a ring to the noise too. Secondly, if the plates are worn, then they will still be relatively loose in the the stack, and so the inertia of the engine is quite capable of whacking them against the basket. Look at the basket tangs too, just HOW deep are the grooves in the offending article you are talking about ? I'd suggest a new alloy basket and alloy friction plates would sort the issue, its HIGHLY unlikely to be gearbox related.......
Could it be a loose alternator nut? When I purchased my bike (996) a couple of years ago, the clutch made a right racket. I changed the basket /plates etc but still noticed it was noisy and the ears on the basket were starting to get notches after only a few hundred miles. Anyway to cut a long story short, I removed the engine cases over winter whilst servicing the bike and found the alternator nut loose. A new washer (£18!!), a new nut, bit of loctite and 280Nm later, the bike is silent (well, near enough Its never felt as smooth nor as quiet so I reckon the marks on the inside of the case and the noise was all to do with the nut coming loose..... Just a thought.
Vid of my old steel basket getting "donged" :biggrin: Note incredible resonance with only one "dong"?? No wonder clutches are so noisy getting clobbered several times a second!... its now quieter with an MPL alloy basket.
Hello Ducati Steve, good to see you joined the forum, I'm meeting up with pablo next time i'm down to pick up his high level can's etc. Do you fancy a beer or two and talk ducati's all evening ? Steve
The lower frequency "knocking" at tickover is the primarys. Yes, the "traditional" rattle comes from the clutch but the primarys are stright cut gears, not helical like most Japs, and the uneven engine pulses cause the knock due to the back lash. Pulling the clutch in, eases the pressure in the gear train and reduces the clank a little. The later bikes use a split, spring loaded primary gear on the crank to absorb the backlash and as a result run much quieter to meet the newer noise regs.
Hello Alan P. I was searching for this matter, and your question appeared. Yes you are correct that the backlash is also producing noise. The comments you got from the other members are also right; that the friction plates are also hitting the outer drum at idle, even the plate stack is compressed by springs. Therfore it will be 2 sources making noise. My bike; a Monster 2006-S4RS, do have the same engine as the 999s, and the increased valve lift on these engines demands large valve clearances. On this engine the heads are pretty noisy too due to that. All of it adds up to a pretty high "music" at idle. It might be OK, but "unnessesay" noise could be reduced. I have done some work at the clutch and made devices in the bottom of each recess for the friction plates, so that the inner friction plate is just about resting to a fixed surface in the drum. This solution is giving a slight inward pressure to the drum, which is then trusting inwards on the bearings. This is "settling" the inner side of the visible notches on the inner friction plate towards the drum, so that they do not freely go back and forth at each firing pulse. I have like 0.1mm positive pressure on some special inserts. Going higher will disturb he contact point towards the plate stack as the frictionplate is resting to the fixed point will be distorted a little. I use an ADLER clutch with a DP outer drum. BUT, i wish to ask if anyone of you have ever tried to remedy the primary drive gear backlash. I have done some research, and what I find is that the Ducati engines with wet clutch do have a split primary front sprocket. There is a spring loaded section to take up the the dead clearance. On most of the Ducati models, this gear do have a conical fit to the crank, and a replacent gear from fixed to springloaded is easy to find, like the one on the GT1000. However, my S4RS do have a spline fit for this gear, and the only bike that seems to have the same spline, and spring damping is the Diavel. On this one, the primary gear ratio is the same too. 2012_Diavel_DucatiOmaha ( note that the number of teeth on gears and many details is not correct on the drawings versus real) On this Diavel pars catalogue it is good illustrations that seems to show DWG 006, parts 7, 11, 12, 13, 15, as needed for the spline crankshaft versons to convert to "anti-backlash". As I now have got a fairly good dampning of the friction plate hammering, the backlash is very well audible, and I recon this would be the right step to go further. Any others messing around with something similar, or converted conical fit gears?. And I agree with you; leave the "love or hate the clutch noise debate" to a separete tread. This is a very interesting technical matter. Ride safely, lymo
FOOKIN hell lads fair play to you, I just ride mine and get baffled when shims clearances and split primary stuff comes into it. ;.)
Hola Lymo, just stumbled across your post. I was searching for something specific on the primary back lash issue. Have you persued it further? did you manage to get some closure on the issue either way, doing something or unable to do anything? I would be very interested to persue the discussion. Ciao...
Hi Cream revenge, been there done that, it is not the clutch noise, wish it was that simple. Its the lower frequency din from the primary gear when the clutch is disengaged. With the clutch engaged there is no noise. It is curious though, if I let the clutch lever snap out from after fully pulling in the clutch lever the noise abates almost completely and then after 15-30 seconds gradually regresses. Something (else) under engineered me thinks!
When the clutch is engaged and all the plates are clamped together by the clutch springs, they (the whole stack) are still free to oscillate and chatter backwards and forwards within the clutch basket slots and the more worn the tabs and slots are, the worse the chattering is. When it gets really bad, the chattering doesn't just happen at rest in neutral, it also happens while riding along on a neutral throttle. The jangling high pitched sound that you hear when you pull the lever in is indeed something different and is merely the sound of the unloaded metal plates ringing like the metal plates in tambourines. If you want to reduce or stop the chattering, you can either replace plates and basket to get closer tolerances or simply apply the quiet clutch mod, which will stop even badly worn plates from chattering, it's just a matter of sticking a friction plate at the bottom of the stack instead of a plain plate, job done. Reduced noise equals reduced wear as well - win/win. I know Steve worries about the theoretical small extra load on a bearing but I've still not come across any documented evidence of it actually causing problems. Thank you@Nelly! I've been worrying about that knock and it's a huge relief to know it's nothing sinister. Yes, I'd like to get rid of it but the potential cure doesn't sound that simple.
