hes sending the cans and the mid section off his 1098 .will this be a direct fit to my 1198 . then i wont need link pipes am i right
I believe with the standard exhaust system it is only the 1198 headers which are different, exhaust stud spacing is wider. Andy
You can down load a parts catalogue from the Ducati.com web site that shows you the system in full. Service and maintenance motorcycle | Ducati The end cans and link pipe look the same for both bikes, it is only the first section where the headers attach to the exhaust port that are different. Andy
I presume they're the slash cuts you posted a photo of yesterday, your standard cans have fixed pipes that connect to the central connector pipe (the curly one) those slash cuts require a short "link" pipe to connect them to the standard central connector (see photo) are these what he's referring to as the "mid section". I don't know if they're all the same but I imagine they are as long as they're not part of the larger 70mm race system.
