Here is a solution to the satnav issue for the 1200r. I have a mount which replaces the central bolt on the steering damper. Its rock solid and places the satnav centrally on the bike. It can be mounted higher or lower depending on which way up the clamp is placed. It does move slightly with the steering when you move the handlebars from lock to lock but as this would only occur on slow manoevring, its not an issue. the mount was designed and made by bob at The Telferizer Custom Motorcycle RAM mounts for GPS Systems If this is something you need give him a call, his number is on the website and he will have you sorted within a couple of days, a really top product.
