749 749 Idle Just A Tweak Up Maybe
Discussion in '749 / 999' started by DucRod, Mar 12, 2017.
  1. i have 2003 749 termis on it and power commander my idle is around 1150 I would like it a little higher is it possible to just turn out the throttle balance screws a little without going through the balance procedure? the bike runs spot on just low idle
  2. Air bypass screw in the throttle body's. just make sure you adjust both of them by the same amount!
  3. That's what I thought just an even amount out I reckon cheers bud
