848 Starting Problems
Discussion in 'Technical Help' started by TheAlfa1, Jan 2, 2017.
  1. If the headlight is staying on then the ECU is either not getting a signal from the starter button (grey body connector pin28, white/blue wire should ground on pressing button) or the lock out conditions are not being met (clutch switch, stand switch, neutral switch).
  2. My money still on the side stand switch.... :)
    • Maybe the side stand switch, as above.
    • Starter button
    • I once left a lead off my battery and got the same issue. It wasn't one of the main cables, but a smaller one that I had managed to get trapped in the battery box and missed.
  3. doesn't it have to be sidestand down and in neutral though Paul? i.e. sidestand switch fail alone will not break the starter circuit? I could be wrong but that's how it works on my earlier/similar bike.
  4. Ah yeah I mean I connect the battery to my 999.
    Just checked all the plugs around the battery/solinoid/ecu all look fine and made good connections.
    So knowing all this, it must be the problem is between the button and the ECU right?
    Surely it can't be a problem with the ECU itself.
    I say that like I don't know ducati at all haha
  5. Is there a definitive way to rule out the side stand switch?
    I thought I had ruled it out buy maybe in wrong.
    Can I bypass it?
  6. yip. check for battery voltage at the starter solenoid then starter itself. you could also quickly check battery earth to engine earth with a jump lead.
  7. Nor sure, but if the thing is faulty I know it can stop the ECU allowing it to start. I think because maybe it has no reference rather than an up/down reference.
    Ages since I had mine, and TBH it never let me down :)
  8. if circuit is as I thought, then little chance of it being the culprit as neutral sensor circuit would have to fail at the same time, you are getting neutral light come on? - try moving bike back and forward just to confirm even if green neutral light is on.
  9. yes, paper clip across the connection. Thats how I had mine for trackdays (stand removed)
  10. have you taken the button off? May be worth some contact cleaner in there, especially if its been sat in a garage a while (maybe condensation??)
  11. I understand, you are saying a value other than switch on or off would alert ECU all on it's own then?
  12. Possibly. I know (didn't a multi on here have it recently?) that if it goes it can cut the engine, but that could be because its running and in gear.
  13. What's the deal with the "keysense" aerial doobrie on 848, 1098 etc, does it not allow clocks to power up or fuel pump or starter, ignition etc? How do you know if it's working or not? :Bookworm:
  14. Yeah I've has the start button and the kill switch off cleaned them and re connected
  15. Been following this with some interest.
    I agree with @Derek 's analysis. I did wonder about the antenna on the keyswitch but I would very much doubt it's that as the immobilzer surely would not allow the fuel pump to run
    So you are getting neutral light and the fuel pump runs, so it appears unlikely that it's a permissive
    The starter button has been cleaned up and checked...................however have you continuity checked the button or tried to short the button connections on the loom side, I'd do the same for the kill switch.
    I'm still thinking switch/assembly at the moment until that is positively ruled out, including the kill switch as that provides what appears to me as the pos voltage to the pilot side of the solenoid.
    I'd then check to see if I was getting voltage at the solenoid when the button was pressed, to ensure the solenoid isn't the problem. I know you shorted it but that's not a positive check of the device itself
    I'd also try to jump off a car battery without the car engine running, as a desperate attempt to totally rule out the battery.............although that's me clutching at straws
    The point is components require to be positively ruled out one at a time
    Apologies if you know all this already or have already carried out these checks
    John
  16. After the "headlight on" test was completed/battery ruled out, it's now a case of getting a clear ignition wiring diagram and working through each component/connector on route to starter with a meter. etc. The many Ducati Forums will get you there in the end @TheAlfa1, Ducati.ms being the most useful one.
  17. Damm I forgot about that headlamp test @Chris
    I suppose then that it's less than likely to be the solenoid as the lights are not going out when the starter button is pressed suggesting that the ECU is not seeing either all the permissives (as I said previously I think this is unlikely if you are getting a neutral light as that shows the gearbox switch is good & I think that's really all you need)
    Have you also checked if you have pos on the Red/Black pilot wire on the solenoid with the ignition on and kill switch set to run? (that's from a 1098 diagram but I'm pretty sure it will be the same)
    So as Chris stated going through the whole starter wiring and connectors, I'd still start at the starter & kill switch check that they are getting the voltage they should and short them at the loom side of the plug to test. Then work your way downstream from there to the solenoid
    Good Luck and I'd be interested to know how this finally gets resolved it you would be so kind
    John
    #38 Old Jock, Jan 4, 2017
  18. Going to have another look this afternoon.
    Need to get my hands on a wiring diagram for the kill switch and the starter button.
    Fingers crossed I can find the problem.
    Thanks guys I'll keep you updated
  19. In a unrelated issue, my rear brake light switch has stopped working I've tried to clean it up but no change.
    Does anyone know a online UK supplier apart from Ducati?
