900ss Foam Dash
Discussion in 'Supersport (1974-2007)' started by Mark9, Jul 14, 2016.
  1. Does anyone know where I can get a replacement foam dash trim for my 1991 900ss?, I've seen carbon ones on eBay but would prefer to keep it looking original, cheers Mark .
  2. Mark, as Wayne says, 2 dial are hens teeth, later ones are still available from Ducati. I ordered one from Ducati Glasgow, it was ordered from the States. Trimming may be possible, I sold it in the end as I found a better surround. Was about £30
  3. C
    Cheers for the replies , yes I'll see if I can save mine first and if not trimming the later one could be the way to go, thanks.
  4. Looks good , how much are you asking for it?
  5. ooh, say £2.5k, comes with a tidy free 750ss and shed load of spares ;)
    (seriously though, have you tried specialist suppliers, spoke to these a while ago about seat foam upgrade, it seems almost anything is possible Foam Types | Cutfoam Ltd
    #7 WAH900ss, Jul 15, 2016
  6.
  7. Mark9
    I have measured one up and have a .dxf file if you can find someone to cut it for you. I sent sim900sl for his restoration (Mk1 Superlight Detailed restoration the saga Begins :) and think he had one done but not sure where. Just message me and will try and find it.
    Think it's closed cell foam and 24mm thick from memory.
    Cheers Gaz
  8. T
    hanks Gaz will do , once I figure how to PM on this site, and once I'm home from this ride
  9. Gaz, thanks for the dfx file but I just managed to source a mint clock set with foam, I also needed the speedo bezel so I'm now sorted, cheers Mark.
  10. Mark9
    No problem, I might email a few suppliers to see how much I can get a few for, may be 10 off.
    It would be good if anyone else could register an intrest then I might have an idea of numbers.
    Better still does anyone work at a foam cutting place,
    Cheers Gaz
  11. I might be interested
  12. Did this ever happen?
    I would be interested in one.
    If not, could somebody let me have the .dxf file to save me recreating it.
    Thanks
    Nasher.
