Anyone got any pictures of the best way to route the front brake lines on a 9*6. I'm using a RCS master cylinder with twin lines + p4 callipers. Ordered the wrong brake lines from HEL, forgot to tell them I was using a RCS master, anyway no problem me sending them back but they need modifying to fit, I just can work out the best way, to make sure I get the right length and end type.
I had exactly the same set up. I had the P4 callipers first with 2xsingle lines and standard master cylinder. When I got the RCS, I found the HEL lines that I already had still worked with the RCS.
