1299 Anyone Fitted 19rcs Mc To They Panigale?
Discussion in 'Panigale' started by Addiction, Jan 5, 2017.
  1. Looking to get 19RCS MC fitted to my 1299s and before i start taking all apart I'm wondering if anyone have done it already?
    It might be a bit tricky with the reservoir kit clearance but not sure.
    As far as i was reading on some other posts there is a problem with the lever touching right hand switch but most likely i'll be changing teh switch for the racing style fitted to the front of MC.
    Any info and pics will be great, thanks.
  2. 19 is no good , you will need 17RCS
  3. Threadjack......
    I was planning to fit a 19RCS to my 1098.
    @ducati dad : do you know if that is suitable for my calipers?
  4. I'm fitting GP4 RX calipers so need 19mm MC
  5. 19 RCS suits the M4 Brembo monoblocs fine.
  6. Are they the M4 as fitted to the s model?
    If so then 19RCS is perfect as they are 4x 34mm piston calipers.
  7. 1299 has m50's does it not?
    899/959 has m4's
    Edit: Assuming we are talking panigale and not 1098
  8. Correct, he was asking about his 1098.
    • Thanks Thanks x 2
