Anyone know where I can find some at a decent price? Recently got some smoked lenses (f&r) and don't want to see the orange blob of a bulb in there.
got these for the GF's Volvo; Indicator Light Bulbs - Chrome Amber 581 12v DC - 581 BAU15s APXB2 watch out, as these specific once have a very slight offset on the pins, but I think they sell some with the pins directly opposite each other. they work exactly as intended in her clear lens rear light cluster. tried the LED option, but too much faff with adding resistors. apparently, a solid state indicator relay can be used instead of using the resistors to get the flash speed down (if you put LED lamps in a standard indicator circuit you will get very fast flash, and if on canbus, an error). Pete
581 (PY21W) fitting, 21 Watt bayonet LED bulbs for cars, vans and motorcycles. These are are canbus error-free, so shouldn't affect your flash rate
Thanks guys for those links. Cheers for this. So the ones I need for the rear after a bit of internet searching are 382 type (same as 581 but with opposite pins) The fronts I think are t10 push fit type for the 749 is that correct?
Have had quite a few issues in the past with LED equivalents, even when they state canbus error free etc. And if they did work it was only for 6 months or so. I'm going to play it safe and just go with bog standard bulbs if I can. Cheers though
