I have just put new clutch fluid into my bike, followed all the steps, bled the air out the system now when I have went to engage the gears I can get into first but now I can't select Neutral or any other gears. Has anyone else had this issue? Do I need to re-bleed the clutch in case there is an air bubble in the system somewhere? Any help appreciated Thanks Neil
The slave cylinder is the bleed nipple that is near the rear sets? And the master cylinder is the bleed nipple on the clutch lever ?
I fitted a stm skipper to my 899 recently and also bled the clutch. When I fired it up I rode up and down the drive and like you couldn't select neutral. I thought it strange but let the bike warm up and then it became fine. Possibly just need to be warm
