Hey Had it a few times now, engine warning light (yellow one) comes on for a couple of seconds. Only happens when pulling away from lights/T junction, only staying on for 2 or 3 seconds. Bikes running perfect (touch wood). Happened twice today in 80mls. Any ideas? TIA
Disconnect and reconnect battery might reset something. Also check earths. Sorted mine out a couple of years back. Also check neutral switch connect at back of gearbox(i think).
I've heard it said that this is the crank position sensor playing up. The engine management thinks that the bile is moving as it is in gear but the speedo sensor says it isn't (as the clutch is pulled in at the time). This causes confusion in the 999's brain so you get a warning light. Hold down the left button on the dash ( I think, otherwise it's the right-hand one) and turn on the ignition. A fault code will appear after a few seconds on the dash which will tell you what the engine management thinks the problem is. Post up the fault code here and one of the brighter 999 owners will convert it for you. If I find my list of codes, I'll be able to do it. But I'm not bright
Oooh. Here - 749/999 Error Codes 1.1 TPS Disconnected 1.2 TPS short circuit to earth 2.1 Pressure Sensor short circuit to power supply 2.2 Pressure Sensor shorted to earth 3.1 Water Temp Sensor shorted to power supply 3.2 Water Temp Sensor shorted to earth 4.1 Air Temp Sensor shorted to power supply 4.2 Air Temp Sensor Shorted to earth 5.1 Battery Hi 5.2 Battery Lo 10.1 Hor. Coil shorted to power supply 10.2 Hor. Coil shorted to earth 11.1 Ver. Coil shorted to power supply 11.2 Ver. Coil shorted to earth 12.1 Inj1 shorted to power supply 12.2 Inj1 shorted to earth 13.1 Inj2 shorted to power supply 13.2 Inj2 shorted to earth 14.1 Inj3 shorted to to power supply 14.2 Inj3 shorted to earth 15.1 Inj4 shorted to powersupply 15.2 Inj4 shorted to earth 16.0 Pump Relay 17.1 LH Fan shorted to poer supply 17.2 LH Fan shorted to earth 18.1 RH Fan shorted to power supply 18.2 RH Fan shorted to earth 19.1 Starter Solenoid shorted to power supply 19.2 Starter Solenoid shorted to earth 30.0 ROM/Eprom error 34.0 Signal Panel Sensor 36.0 Speed sensor 37.0 Immobiliser (transponder) 37.1 Immobiliser (antenna) 37.2 Immoiliser (instrument panel serial driver) 37.3 Immobiliser (serial cable disconnected) 37.4 Immobiliser (ccm serial drive) 37.5 Immobiliser (key not recognised) 37.6 Immobiliser (ccm program) 38.0 Can Line error
You can only bring up fault codes using the dash button if the EOBD light is on constantly. You need to connect the bike to diagnostic software to read any stored fault codes.
Ok, so I just install one of them and use the 2 connectors in this thread? http://ducatiforum.co.uk/index.php?threads/40968/
Some of the BT Elm327 will not connect. This type has been reliable ELM327 OBD2 OBDII Bluetooth V2.1 Auto Car Diagnostic Scanner Tool Android Torque | eBay
Right, ordered those 2. I take it that it plugs in near the head stock on a 999? What does the red and black crocodile clip connect too?
On the 999 the diagnostic is on the left side of the battery box. It's a 3 way Superseal connector with 2 wires into it. It should have a plastic cap over it. Red croc to +ve battery. Black croc to a good Earth on engine or frame. Never connect it to the battery and you will avoid damaging the ECU.
My 2003 model 999 always done that, it didn't bother me as the light cleared as soon as the bike started to move again. Never found out what it was.
Ok, so it's plugged in, OBDII scanner, next to battery. I can now see a com 6 & 7 in Windows (win7). Both show as Bluetooth. JPDiag does not respond when I connect on either port on fast or slow. Bike ignition is on. Any differing ideas?
