hello lads and gall. ok ive got everything now exhaust wize . but am stuck with ecu . cant find anyone to flash the ecu chip etc just to sort out the fueling is there any other way i can go to sort this . its only cans ive puting on . please adsvice dont want to go power commander if i can help it
Ah - didnt know it was that expensive....ive always taken my bikes down there for a custom mapping...
i gotta say if you go with the ecu flash then you can unplug the flapper valve motor also...and blank off the o2 sensors. PCV's just get in the way...plus you end up having to add a box in to stop this, that or the other. A flashed ecu is a much tidier solution...
Try hilltop motorcycles.... He's does ecu flashing... 07449 006300 Sent from my SM-G935F using Tapatalk
