Pop Bang
Discussion in 'Ducati General Discussion' started by Cream_Revenge, Mar 11, 2017.
  1. £60 + PnP from JHP. Ordering today.
  2. Just tweaked it.
    There's a procedure somewhere for it.
    Bikerboy / Brad Black IIRC
  3. I think it depends on the chip if you can trim or not.
    Hopefully sorted, wondered if JHP would still have some on the shelves :upyeah:
  4. apparently they make to order. Parts guy waiting for Mr JHP to come in to get him to cut/burn or whatever.
  5. Mine had the proper chip, still needed a trim.
    Hopefully sorted with new chip :)
  6. John Hackett at JHP did me a custom chip for my 853 and it runs perfectly, after fitting I took the bike to Neil at Cornerspeed to fine adjust the co2 levels.
    Steve
  7. So what's good stuff for fixing a leak at an exhaust join?
  8. A big hammer and a long run up ;) :tearsofjoy:
  9. Exhaust gasket filler... Get a tube of it.
    Sent from my SM-P900 using Tapatalk
  10. I would avoid gasket goo and gum gum type of sealer, they set too hard and make removal very difficult, a smear of heat resistant silicon is all that's needed.
    Just my opinion.
    Steve
  11. Teflon exhaust tape works very well. I used this for my track Suzuki RGV250 which uses slipon pipes to an exhaust flange in a very similar way to Ducati's.
    Being tape it does not blow out quite so easily and won't melt.
    #56 Red998, Mar 14, 2017
  12. Silicone sealer and Lambda sensors don't mix.
  13. JHP never got back to me. So got one from Louigi Moto for £35 delivered :)
  14. Sorted then??
  15. Need to wait for Mr Postie to do his magic then test ride.
    If still pops/bangs i'll have the pipes off/on (need a polish anyway) and try again.
    If still going pop/bang it's either live with it or a trip to the tuners.
