Hi im having trouble with my 944 engine not pulling past 6k.has any one had this issue.could it be as simple as poor plugs coils? Or furl starvaition.or ecu reset?bike runs great otherwise.any help appreciated Sent from my iPhone using Tapatalk
Is it injected? If so check fuel pipes in tank arent leaking. With a fullish tank, switch on ign to prime pump and watch for bubbles through filler hole.
Yep injected.i had trouble with the hoses inside the tank when i first got the bike so replaced them.ill check that again to make sure they are still tight.thanks 900streetfighter Sent from my iPhone using Tapatalk
I did s ohms test on ignition system.turns out i had a fair bit of ohm variation on rear cylinder coil.secondary loop fu**kd. Sent from my iPhone using Tapatalk
