Hi I disconnected the battery to connect heated glove leads then reconnected cables back. Put key in the on position and system checked itself as normal then nothing no ignition/neutral or oil lights on. Press starter button and nothing. Headlights, indicators, horn and brake lights all working. Didn't get as far as plugging in heated gloves and battery is fairly a new Motobatt so plenty of charge. Checked fuses and all good. Any ideas please.
Sounds like the immobiliser needs resetting. The Immobilizer System; Keys - Ducati MONSTER S2R 1000 Use And Maintenance Manual [Page 16]
Hi Chris thanks for reply. Unfortunately the EOBD light does not stay on to enable you to enter the code. All lights go out apart from the immobiliser amber one which flashes. Cheers
There are a couple of software experts on here, but my memory failing, it does sound like a fault then..
You have probably done this but worth checking. Mine won`t start unless the tank retaining gubbins is all properly screwed back together.
Hi all sorted at last phew, retraced all wiring and found a loose connection which I missed first time round. Thanks for help everyone much appreciated.
