Is or If the up-map key is locked to to one bike can the key be flashed to be put on another bike? Sent from my iPad using Tapatalk
The upmap can only be loaded by a dealer using the DDA. When it is uploaded it is swapped with the standard map which is then on the stick. It seems to me that even if you could copy it you wouldn't be able to upload it.
