959 Shift Light Question.
Discussion in 'Panigale' started by Kevster84, Mar 24, 2017.
  1. So I've looked in the manual and tried the search function but couldn't find an answer.
    Is the shift light on the 959 adjustable? Only I noticed tonight I hit the limiter in second and red lights wernt on to shift gear.
    They do work as I've seen them light up before.
  2. It's not adjustable I've tried a few times
    There is a sub menu in the settings but it doesn't actually let you change anything as If Ducati have locked it
    I think in wet mode the light flashes a lot earlier though
  3. I'm in race mode. I just wasnt sure if id accidently changed it when I went in to the custom menu and changed the engine braking. So the light is just set for a certain rpm in each gear and comes on automatically.
