Single Sided Rear Wheels
Discussion in 'Technical Help' started by ian shobbrook, Feb 21, 2017.
  1. can anybody tell me if the 916/748, hypermotard 821, 939 ,monster ,multistrada etc rear single sided wheels are interchangable ie are the offsets , spindle width, length etc the same , so i can keep standard allingment without having any machining done to centre them up .any help would be helpful thanx
  2. Think ealier 748/916 etc and 848 are same size hub.
    Multi, 1*98 are and I think Panigale too (not 959) again all driven by hub size
    Not sure about monsters But if you match the hub I'm 99% they'd fit the same Superbike and visaversa
  3. ok thanx ive seen a 821 hypermotard wheel im trying to find if that will line up correctly on my 916 rear arm /hub
  4. Yes they do fit
