999 Sound Deadening Panels
Discussion in '749 / 999' started by Cream_Revenge, Jan 9, 2017.
  1. Question: the sound deadening padding inside the fairing either side of the engine, is there any other point? Do I need it? Anyone run without them?
    Cheers
    • Nuke Post Nuke Post x 1
  2. Heard they don't make much difference - been mentioned on here before, but why take them off if they are OK :)
  3. 'Cos I'm going to spray the fairing and want to give the inside a light matching dust.
  4. Pop em off and pop em back on again :) If you're careful the spring steel fasteners can be removed and re used.
  5. Is there a plan for people that ain't to hot on careful?
  6. Yes, leave them off :Hilarious:
  7. Take them off.
    I did and it made cleaning easier as any dirt gets washed off the insides rather than sitting under the foam.
    I had to use cutters to get the spring washers off without damaging the tabs.
