Evening. Not sure if I'm mistaken but I seem to remember I could start my bike in neutral without touching the clutch. Starting today I had to have the clutch pulled in regardless of neutral or sidestand up or not. Not ridden since October and done lots of changes since then. Should she start without the clutch in? At least she started Cheers
I KNOW! What sick individuals there are out there! Thing is, neutral light is on on the dash so ECU must know it's in neutral so why does it not allow starting without the clutch?
Dodgy neutral switch maybe, have you run the engine or better still taken it for run to get it up to temperature?.
No. Still in bits. Just started to check fuel pump after putting tank back on but thought it strange I needed clutch in.
Can't be side stand switch can it? Should start with side stand up or down if in neutral. Which would mean neutral switch. But that must work or the green light wouldn't come on on the dash.
Yes, when you release the clutch in gear with a faulty stand switch it would stall the bike (if ecu thought stand was down)
