Hi all, Just wondering if someone can share some knowledge please. I am trying to find out what is the correct full system for my bike, it is a 2003 749s shallow sump and the grey swing arm obviously. Been searching for this for some time and a lot of info but trying to find the exact answer and photo has been proved a bit hard. Everything seem to contradict itself, some say the "banana" style ones are only for the later swing arm, some don't... Any photos about of an system for a system for shallow sump with grey swing arm about. Found one online, the "banana" style as some call it but then on the comments it does say it is not the correct one.... I remember seeing a parts catalogue for the termi's somewhere with part numbers and so on but cant find that anymore. I have a system to try on it but it is from a 2003 999s grey sing arm and deep sump , let's see if it fits but before I go ahead want to know a little bit more about it. By what I read somewhere it might fit but it will be very close if not touching the sump in two place. Cheers
Deep sump wont fit a shallow sump and visa versa, just converted mine from shallow to deep as I changed the motor. Banana type is for the black arm only information I have. I have a banana on a black arm if you need some measurements let me know. On ebay they are normally marked up grey or black arm, grey arm ones are always a big single normal type of pipe.
You converted it as I modified the exhaust pipes? I have access to a grey arm ( not banana style) from a 999 deep sump, if I can make it work then it is good to go. to be honest seems it is impossible to find the correct one for my bike ( grey sing arm with shallow sump )
I cut and welded the old shallow sump pipes and made them fit the deep sump, its no problem on ebay you have plenty of bends and pipe albeit its thicker walled than termi pipe which is 1mm I think its 1.5mm on ebay but you dont need a lot and so the weight is no big deal. if you wait and keep looking you find a system.
Yes I been looking for a while, I have the pipe and box but want a full system... never enough hahahah. I will keep looking for it if not then some cute and well it is.
