03 749 Gear Lever Wanted
Discussion in 'Wanted' started by chizel, Jun 12, 2018.
  1. Hello dudes/dudettes
    I need a gear lever... it' s for an 03 . Don' t know if any different to later models. ..
    • Nuke Post Nuke Post x 1
  2. Got 1 you can borrow if u need to get on road. K.
  3. Thanks mate. I can ride it with the bent one but obviously it ain't ideal. Need a replacement. .
  4. Same on all...
    457.2.013.1A 2003 Ducati 749 Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2003 Ducati 999 Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2003 Ducati 999r Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2003 Ducati 999s Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2004 Ducati 749 Dark Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2004 Ducati 749r Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2004 Ducati 749s Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2004 Ducati 999 Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2004 Ducati 999r Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2004 Ducati 999s Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2005 Ducati 749 Dark Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2005 Ducati 749r Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2005 Ducati 749s Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2005 Ducati 999r Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2005 Ducati 999s Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2006 Ducati 749r Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2006 Ducati 749s Brake control lever REAR HYDRAULIC BRAKE
    457.2.013.1A 2006 Ducati 999 Brake control lever Rear hydraulic brake
    457.2.013.1A 2006 Ducati 999r Brake control lever Rear hydraulic brake
    457.2.013.1A 2006 Ducati 999s Brake control lever Rear hydraulic brake
  5. What about gear lever like what I need?
  6. Sorry, like wot I need init...
  7. Oops... I thought with you being from the Southern Hemisphere that was correct for you? :thinkingface:
  8. Same if you stand on your head :):upyeah:
    456.2.033.1A 2003 Ducati 749 Gearchange lever FRAME
    456.2.033.1A 2003 Ducati 999 Gearchange lever FRAME
    456.2.033.1A 2003 Ducati 999r Gearchange lever FRAME
    456.2.033.1A 2003 Ducati 999s Gearchange lever FRAME
    456.2.033.1A 2004 Ducati 749 Dark Gearchange lever FRAME
    456.2.033.1A 2004 Ducati 749r Gearchange lever FRAME
    456.2.033.1A 2004 Ducati 749s Gearchange lever FRAME
    456.2.033.1A 2004 Ducati 999 Gearchange lever FRAME
    456.2.033.1A 2004 Ducati 999r Gearchange lever FRAME
    456.2.033.1A 2004 Ducati 999s Gearchange lever FRAME
    456.2.033.1A 2005 Ducati 749 Dark Gearchange lever FRAME
    456.2.033.1A 2005 Ducati 749r Gearchange lever FRAME
    456.2.033.1A 2005 Ducati 749s Gearchange lever FRAME
    456.2.033.1A 2005 Ducati 999r Gearchange lever FRAME
    456.2.033.1A 2005 Ducati 999s Gearchange lever FRAME
    456.2.033.1A 2006 Ducati 749r Gearchange lever FRAME
    456.2.033.1A 2006 Ducati 749s Gearchange lever FRAME
    456.2.033.1A 2006 Ducati 999 Gearchange lever Frame
    456.2.033.1A 2006 Ducati 999r Gearchange lever Frame
    456.2.033.1A 2006 Ducati 999s Gearchange lever Frame
  9. The only bike that was built in NZ ( to my knowledge ) was the best v twin ever... and everything was on the same side as normal stuff ... fool...
  10. OK... so they is all the same.. ta...
    Now who has one for me!?
  11. No one :)
  12. No one?
  13. How badly bent is yours? Will it straighten with a bit of heat?
  14. Have you priced up a new one? :thinkingface:
