Speedo drive on 900 from front wheel if its 3 spoke, 1000 is off rear wheel with sensor. Might need to grind 1.5mm off speedo gearbox to get wheel central. I did this when I put multistrada 1000 legs and SS yokes with a 996 wheel on a 907. All SS injected legs are same length, carby are 30mm shorter.
Yes but one is leaking, from the upper part of the fork (not the seal/stanchion area). Brake cable has rubbed the f**k out of it.
Chck it first, but think the DS willbe 65 mm spacing and not a 17mm axle. May be yours isnt either?? I only know the smaller variant, 600 and 750
Do you mean through the gold shroud? Might be easier to find a secondhand replacement for that than trying to match up forks from another model.
