1000ds Headlight
Discussion in 'Supersport (1974-2007)' started by richgilb, Apr 9, 2015.
  1. Can anyone confirm that the last 1000DS headlight actually came with plastic 'glass' and the others had real glass at the front?
    And if I am correct here, is the fitting the same, ie could I put one on a 900?
  2. I've had both types fitted to the 900 SS/IE I had, glass and plastic. They are identical at the back so should fit any Injection SS as the headlight frames are all the same.
    Ian.
