1098r/1198r Or 1x98rs Manual?
Discussion in 'Technical Help' started by Air Duck, Oct 23, 2017.
  1. Can anyone help, I'm after a workshop manual for the R models as in the title?
    TIA! :upyeah:
    • Thanks Thanks x 2
  2. Top man! Thank you very much indeed :upyeah:
  3. Hi Rob,
    I'd be most grateful if you could be so kind and send me the same link please,
    Much appreciated in advance,
    Thanks and regards,
    Michael
  4. Here you go - 1098R Service Manual
  5. Thank you very much for the Manual Robarano,
    Best regards,
    Michael
  6. Hi Rob,
    Question for you if you don't mind, was out for a Sunday run today on the 1098R was doing about 160+kmh when the bike decided to stop running screen went blank, red engine light came on and she wouldn't start again, engine turned over, screen was okay but won't fire up. Towed her back and now have to figure out whats the wrong with her......any ideas on where to start...thanks Michael
  7. Sorry :confused: I'd start with error codes and getting the dealer to plug it into the diagnostics before you start spending money.
  8. Sounds like a plan, thanks Rob. Should the shop charge for the diagnostics check? I will keep you posted on the results..
  9. Hi Rob,
    Following a detailed diagnostic check it was discovered that the fuel hose from the fuel pump to fuel filter had come off the fuel pump, hence the sudden shut down at speed. New hose and clips were installed and all good to go. So she is back home ready for another run this weekend. Thanks for your help and advice, Michael
