1098 1098r Clunky Gearbox When Downshifting
Discussion in '848 / 1098 / 1198' started by ducatidude1098r, Jun 12, 2015.
  1. Hi Guys
    I have a very low mileage 1098r, previous bike was a 1098s. I noticed that at times when downshifting it clunks into gear, has anyone experienced this on their R or other 1098/1198 models. Any ideas greatly received, many thanks
  2. Check your chain tension. I have found that a slack chain can cause what you are experiencing. Hopefully it's something as simple as that and not expensive. Andy
  3. search 1098R and gearbox........
  4. Meh, more like owners who thrash a very torquey bike and have little gearbox sympathy. The 1098R gearbox is the same as the 1198 save for 2 gears.
    That being said, superfinishing the gears makes a huge difference. Mine is butter smooth.
  5. search 1198 and gearbox.......
  6. +1 on that. Just done 4 days at Almeria and not one gear missed! I do use an HM quickshifter. I only use it from 3rd up to 6th, always manual clutch down the way. The QS feels super slick and I sense no mechanical violence so it must be set up ok.
    I believe the Nova gearbox is the Holy Grail.... Is this true? I know they're circa 2.8k ouch...
    As pointed out, there is a bit of grief with 1098R gearbox's. But its not just 1098R's. Think about it, you're smacking from one steel gear to the next whilst putting down 180+ HP. That's a lot of mechanical stress over a small area.
  7. Thanks for the replies, my chain is loose so have bought the adjustment tool so will give you all an update once I've tightened it, fingers crossed :upyeah:
