Hi, 2007 1098s tri - headlights have stopped working. Now the headlights full beam/low beam etc will only work if I hold the passing light switch in. Any ideas? Cheers
Once you get the nosecone off you can't miss it, although IMHO it's a fekin stupid place to mount a relay If I remember right the flash bypasses the relay that is why it works
