1198s Front End Onto Xx9 Series
Discussion in '749 / 999' started by t3scn, Oct 22, 2014.
  1. Hi all,
    It's been done a fair few times but I'm struggling to find details on the above.
    Swapping the front end to use 1198 yokes and front wheel spindle, do you need a 1198 or 1098 front wheel or will the xx9 wheel be fine?
    Any comments would be most helpful
  2. xx9 wheel will fit.
    I have 1198 forks on my 916 and am using a 916 wheel, just needs a spacer to replace the speedo drive plus 15mm offset discs.
    But as the xx9 has no speedo drive cutout and already uses 15mm offset discs it will be fine.
  3. Cheers just that response I was after Dukedesmo
