749 12 Hole Injectors To 749s
Discussion in '749 / 999' started by bluey, Nov 12, 2015.
  1. Someone recommend this to me so I thought Id ask here for your opinions.
    Single hole injector is said to have issues with pooling or poor spray when well used. A permanent fix is to fit a later 12 hole pattern and map to suit.
    Bulls**t or worthwhile?
  2. yields fair results I believe.
  3. I have the later 848/1098 purple injectors on my 748RS with R shower throttle bodies and they are a direct swap. You will need to map the ecu to get the best from them and don't be surprised if the consumption gets a little worse. IMO it's a worth while up grade. Andy
  4. The 848 injectors are what have been recommended.
  5. Not a cheap item although they do come up on eBay occasionally which is where I picked mine up from. Low down response and tick over are a lot better. Andy
  6. #6 deleteduser211220, Nov 13, 2015
  7. I have a pair of purple injectors new that I bought for my 748r but never used if you are interested.£100
  8. Thanks all.
    Will get back to you about the injectors.
  9. A worthwhile mode even if they're not worn going by car usage.
  10. Good price for new ones.
