Desert Sled 14t Front Sprocket Change, Engine Fault Code
Discussion in 'Scrambler' started by MoxSled, Jun 12, 2022.
  1. Hi All
    I have searched the forum but can't find any answers so I apologize if this has already been done.
    I have a 2022 Sled, it is a fun bike to ride however I found 1st gear very high so I put a 14T front sprocket on it, very happy with the ratio now however the engine fault light keeps coming on, reset it and a few Kms it comes back on, I understand this is an issue but it appears to be the euro 5 bikes only, the question is how to fix it?.
    Are there any updates for the ECU or settings that can be changed via ODB2 plug etc.
    I see some guys have just put tape over the light but I wouldn't mind getting a proper fix, the fault code is P0919 gear select is what it comes up with.
    Any help much appreciated.
    Cheers
    Paul
  2. All the posts suggest no solution other than reverting to 15 tooth sprocket.
  3. Yes that is what I have found, the best suggestion has been grey tape over the icon
