For Sale 158hp 996r/998s Engine Louigi Moto/cjs Blueprinted , Leovince 57mm Fs Exhaust & Ecu
Discussion in 'Parts, Accessories & Clothing For Sale' started by funkatronic, Oct 6, 2017.
  1. I'm selling my very special power plant, brain and and lungs from my much loved 998 track bike .
    I had planned to track/race it again, but moving abroad means thats not going to happen anytime soon therefore its reluctantly up for sale to a lucky individual.
    i might be prepared to split, so do let me know if you are interested in the engine or exhaust on their own, but i think these items together with the ECU might be of interest as a package.
    This engine is refreshed and ready to use.
    It should be of interest to if you are in the process of building up a 998 track/race bike or special custom road bike.
    This should be a drop in replacement for 996R/998s & (i think) 998FE 2002-2003
    This package will save you a lot of time (and a small fortune i have the receipts!!) and give you a big power an torque increase and improved throttle response.
    Specs
    Complete Nut and bolt no expense spared build and blueprint by Lougi Moto/CJS Racing
    2002 998s/996R Galsi 7 alloy Sandcast crank cases
    Pankl Titanium Conrods
    New Pistons & rings & re-honed barrels
    Balanced crank
    749R heads and Cams modified by CJS Racing/Louigi Moto
    All new bearings seals and internal components
    Louigi moto lightened flywheel
    Louigi moto oversized belt pulleys
    Leovince Full Titanium Exhaust System 57mm for Deep sump Testastretta
    Titanium End Cans with stainless pipes - good condition - very well made, great looking, mega sound and big performance
    OEM Magnetti Marelli 998s ECU dynoed and re-mapped by CJS Racing Dyno’d at 158rwbhp with 86ftlbs torque
    The engine uses 100% OEM parts (apart form the flywheel and belt pulleys and sight mod to the heads) for ease of servicing and reliability.
    I ran this for approx 15 trackdays and it performed fantastically.
    It was more than quick enough with a massive amount of usable mid range torque which allowed me to lose most in-line fours out of corners and the improved top end is eye popping!
    At the end of the season it went back to Louigi for a refresh
    its been checked over thoroughly and rebuilt with new seals etc so is ready to race;
    new main bearings
    gearbox and output bearings
    big end shells and bearings
    and some gearbox cogs due to heavy wear (bloody quickshfter!!)
    i might be prepared to split but It makes sense to offer these items together first.
    NB The exhaust is for deep sump Testastretta motors only
    As mentioned above, this should be a drop in replacement for 996R/998s & (i think also) 998FE 2002-2003
    i believe it will also fit in a 748R frame but i don’t know about other mods needed for this bike
    To fit in 748/916/996 can be done, but this requires frame and some other modifications
    The engine will go in lots of bikes (749 999)
    will post some pics up this weekend
    any questions please send me a PM
    #1 funkatronic, Oct 6, 2017
