17mm Speedo Drive
Discussion in 'Wanted' started by oilyfinger, Mar 21, 2013.
  1. wanted for my 1990 851 but not sure if any 17mm one is suitable. After a cable aswell I suppose as that's the reasons the drive unit is f00ked!
  2. I don't know your model details, but if you would care to take a photo of the wheel hub without a drive in place and a few dimensions, I might be able to tell if an SS one will fit.
    Photo first.....
    AL
  3. Thanks Guys,
    I actually picked up one from a mates last night. it was a 17mm which he bored out to 20mm to fit the bimota, so I will just sleeve it down to 17mm again.
    Steve- thanks for the tip on the SS cable, i'd looked at those, the only difference being there's a thrust washer on the 851 part, I wasn't aware the length was different. I have a 900 SL in the garage, so I was going to pull the cable of that and try it. they're cheap enough at about £11.80 from Ducati tho, cheaper than a pattern one on ebay!
    Will let you know on if it all fits ok,
    Phil
