848 185 / 60 On The Rear Of An 848 ?
Discussion in '848 / 1098 / 1198' started by Fastmonkey, May 18, 2014.
  1. I'm looking for some part worn Super Corsa's for track day use and most of them for sale seem to be 120/70 and 185/60's instead of the 55's on road spec.
    So question is why are people using 60 profiles, is it more corner surface area and is there any issues running this size ?
  2. On track loads more grip. On road no idea
  3. is that cause the edge of the tire doesn't drop off so much due to the higher profile then.
    i might have to give that a go......
  4. Its the % height v width so its taller. Ie there is more rubber at 3/4 lean than upright if you look at the ones I have. Makes it turn quicker so you'd need to reset your ride height
