I read into this as I've got some perfect asv levers off my 848 which I'd like to put onto the 1199 I will buy at some point. They do fit, but apparently the push on the master cylinder is different. So not ideal but will def fit. If they did fit I'd keep mine as I'll only end up buying another set
Well if that's true maybe mine will stay. I've provisionally sold them but not heard anything from the buyer for 2 days so let's see. If wants them I'll sell them If not I'll keep and try on the 1199.
When you first present them to the cylinders you think they won't work, it's just that the stock ones are very different in style but once you've transferred over the little bar it all come good. You still have to punch the bearing out the old ones but a smooth centre punch worked for me
