Having just upgraded the 748 wiring from the alternater to the regulator I found that the Anderson Super pole 2 pin connector I fitted did not work (no continuity through one pin) this was probably my fault but I have no confidence with this make now, can anyone recommend a suitable fitting. Thanks Steve.
Fitted two single plugs and parted the two yellows from the alternator back aprox 40mm from the plugs so as to let more air around them keep them a little cooler. The bits for it came from Vehicle Wiring Products. Ref-LCC 1 way connector 8mm blade terminals They have worked fine on mine for years. brian.
