44,000 Miles
Discussion in 'Sport Touring' started by Sam1199, Sep 8, 2015.
  1. Just put new belts on my ST4, got them from Exige on here. Good stuff, good service too.
    Bikes runs beautifully, really smooth now.
    New HEL brake lines because I thought I should. The brakes were a bit slow so I put new carbon Loraine pads on too. My rears were finished and the fronts were low. I'll report back on them when I've given them a little more time but the rear is already a huge improvement.
    New Oberon clutch slave cylinder. Needed it. The seals go every so often, thought I'd just bolt a whole new one on and see how it goes.
    If you maintain them, they are reliable.....probably put a curse on it having said that.
  2. Wow, you've overtaken my 999S :)
    The Oberon will delight you :upyeah:
    And Elise does belts now? He kept that quiet! ;)
  3. Good work Sam :)
  4. Top darts mate!
    Had a mileage achievement myself lately.
    I'm running Carbonne Lorraine street pads myself and I find them very good.
    I replaced the OEM Brembo discs with Blackshadow ones and ran a set of EBC HH pads on them first.
    I didn't like them. They were grabby and juddery in the dry and a little panic inducing int the wet. There was a milisecond delay before they bit in heavy rain and it was always an arse twitching moment.
    I had the same issue before on an old ZZ-R when I put EBC Prolite discs on with EBC HH pads. it was entirely cured by the CL pads — and guess what this time? Same again.
    The only thing is, I should have gone for the HH CL pads as the street ones are just a tad underwhelming and at this stage I really don't need to worry about disc wear.
    Interested to hear your own experience with the CL pads.
    A
  5. The latest pads Cl do are
    Rear: Rx3
    Front: XBK5's. 2 sets, 1for each side. The 5 is the latest model.
    This is the setup for a Sportsbike.
    The more I use them the happier I am with them.
    You're doing well with your bike.
