4v Cover On 2v Engine
Discussion in 'Ducati General Discussion' started by Nottsbiker, Apr 2, 2016.
  1. Hi All,
    Quick question for those in the know...
    Will a 916 clutch side engine casing fit onto my 2v M900 engine?
    Many thanks
    Ben
  2. It would but you'd need to blank off the water pump drive. it would look a bit weird.
  3. Thought the pump was on the other side iirc
  4. Sorry, you're quite correct. :rolleyes:
    The clutch cover will fit straight on, the only difference is the colour is a different shade of grey.
  5. No problem :)
    Thanks for your help
