I am looking to dyno jet my 600s and fit a new exhaust ( standard at the moment ) any tips and advice . I don't have a massive budget. There are a number of different types on ebay would like a bit of advise from anyone that has fitted one cheers H
Before you buy any of the zorsts available, I would check to see if it has already been Dynojetted...... ...........if it has Stage 1 DJ kit fitted, it would work OK with the OEM zorst...... ......with regard to type of zorst, it guess it all depends whether you want to go high-level or not........in which case you will probably need to consider the link pipe as well....... Whichever you go for, I found it best to have the type with separate link pipe and can, otherwise getting it fit can be a real b*****d.
I've got GPR carbon cans on my 1000ss without any dyno or ECU up grade. Bike runs great and the sound!, wow!, sounds better than my Panigale with Termis!.
