600ss forks
Discussion in 'Supersport (1974-2007)' started by j13cooper, Sep 30, 2013.
  1. Im just about to purchase a pair of showa forks for my 600ss to replace my marzocchi ones as one leg is past it.
    Are they a straight swap?
    Silly question I expect.
  2. Depends one which Showas..............If they are the earlier fully adjustable ones from the carbed SS..........Yep, straight swap....
    But as far as I am aware, some of the later Showas (from the IEs) had wider spaced brake caliper mounting holes.....Not so straight a swap.
    AL
  3. Al is right the calipers mounts are different, the carbys are 50mm and the ie's are 68mm I think. I bought newer calipers for mine to do a twin disc conversion so found this out the hard way!!
  4. Brilliant thank you lads they are off a carby ss... I will go ahead with my purchase thanks.
