600ss Parts Suppliers
Discussion in 'Supersport (1974-2007)' started by Bison, Feb 20, 2022.
  1. Hi Folks,
    Are there independent parts suppliers for the above bike?, apart of course from Ducati. For my Guzzi's for example there is Gutsibits. I know Stein Dinse do some Ducati parts too. I'm thinking of the 600ss in particular. All replies most welcome.
    Cheers,
  2. There is a Forum on here that lists alternative parts and sources, will see if I can find it, you might with a bit of exploring.
    EDIT Nope.. no luck.. @El Toro ?
    #2 Chris, Feb 20, 2022
  3. Stein Dinse are really good, however postage costs are high if its only for wee bits. Worth getting a load at once. You would be surprised how much you can get from Ducati dealers and sometimes surprisingly good value. EBay great and you can get the part number from Stein Dinse micro fiches and search Google, comparing with different sources. There's also specialists like MdinaItalia and Gutsi bits do Brembo parts that are the same. Cross referencing stuff is vital and for example, oil filters and belts can be much cheaper if they are Dayco or Mann for example. Hope this helps
  4. Thanks folks, very helpful.
    Alan.
