A lot to do as yet............but I'm pleased with how it's turning out..........(20" x 30") The alternative title could be "Dyke on a bike"
There's a whole bunch of 'dykes on bikes' for real, I met 'em in Brighton. Pretty was not a word that sprang to mind
So I have drawn the boob and you are drawn to the boob.............. It won't be quite so obvious when it's finished........there is still shadow and darker tone to add to the skin and other areas..... ......because it's oil paint, and only partly dry, I'm having to wait for it to dry out more before I do any more to it.......
Oh well, you won't be buying it then...........Like I said earlier, it won't show as much when it's finally completed.......... I wasn't convinced the jacket would stand out enough against the skin, so I deliberately left the skin areas light-ish to be able to apply shadow over it when the light grey has dried out....and because I used a lot of white to get the different greys etc, it will take time to dry 'cos white does. I have loads more cluttering up the place...........I currently have five on the go, all in various stages of completion.
Al I appreciate the work that's gone into these. Miss the smell of oils . Good to have a hobby and your paintings are a credit to you.
I'm OK...............I'm using Castrol R! Thanks BTW........Note I don't paint in oils like most people do......... Previous stuff is airbrush. Business stuff is watercolour and a bit of PShop.
