848 70mm Termi Headers
Discussion in '848 / 1098 / 1198' started by BIG M, Mar 22, 2020.
  1. Quick question:
    I know the 70mm Termi header pipes for the 1198/1098R are different to those of the 848 and 1098/S, but are the 848 and 1098/S 70mm Termi headers the same?
    Cheers:upyeah:
  2. So the 1098 and 848 are the same mounting to the heads, and as you say different from the 1198 (+1098R) you can make them fit with a little persuasion...
    be wary about what is described as a "70mm" system as most are not, apart from a little bit where the two headers join!
