Hi, I'm looking for some advice or inspiration... A couple of weeks ago I started the bike up (2000 748R) and washed it, and it wouldn't start afterwards. The alarm (Datatool Veto Evo) would re-arm itself with the ignition on, and although it was priming the fuel pump, there was nothing on the starter button. On checking the fuses, the 7.5A fuse to the stop light / horn had blown - I understand this is frequently used as the ignition feed to the alarm, so would explain that. I replaced it and it started fine, but it is consistently blowing the same fuse on tickover, and also with the engine off when I activate the brake light. I've checked for chafed wires, but nothing to see. Any thoughts? Might this be down to a mal-functioning alarm? Anyone seen this before? Thanks in advance, Nick
