748s Ecu Pinouts
Discussion in 'Technical Help' started by AngryBaldMan, Sep 14, 2015.
  1. Had a hunt about but I can seem to find a diagram for the pinouts on the ECU of my 748s, can anyone help?
  2. Download the owner manual from the Ducati Maintenance site" the wiring diagram is at the end. You can trace the pin outs from the ECU to components.
  3. Thanks!
  4. 1. Coil H
    4. Relay switch 5amp
    5. Injector
    10. Diagnostic
    11. CPS
    13. Water Temp
    14. TPS v supply
    15. Diagnostic
    16. Earth
    17. Earth
    19. Coil V
    22. Injector
    23. Relay switch 20amp
    26. Starter button
    28. CPS
    30. TPS output v
    31. Air temp
    32. Air pressure
    34. Earth
    35. Relay 12v supply 5 amp
  5. This forum is so good.
