Hopefully somebody can shed some light on my issue, after recently returning from the isle of man, my 749 seems to be have mad momments starting when warm, just keeps turning over and over, and not firing, from cold its fine, I have recently put a brand new yuasa battery on, so the output is fine, can anyone advise..... its doing my swede in......
Would have guessed at your battery cables and connections, as when warmer, the resistance goes up. But you say that it turns over like a mincer wanting a bit, so that would say the voltage at the starter is ok. worth a look, clean and refit (and where possible maybe upgrade) just to eliminate the cables.
