For Sale 853cc Engine
Discussion in 'Parts, Accessories & Clothing For Sale' started by Android853sp, Nov 14, 2022.
  1. This engine has been the subject of a build thread, where more pictures can be found. Built by Moto Rapido in 2015, using a 2001, ex Stuart Easton 748RS engine as the donor. A total nut, bolt and bearing build with an EVR 748R/853 conversion kit. The engine retains all the RS parts and is sold with a modified 748R shower injector set up (machined 54mm diameter inlets and 12 hole injectors) and a dedicated EPROM that fits the 748R, 1.6M ECU. Initially run in on a dyno and ran absolutely sweetly, 130+ rwhp. Used for 2 track days before being given an oil and filter change and retired in 2016. Wet stored in my dining room ever since. As with everything I list, the price is negotiable ...... to a point. Asking £3000, collected as it is bulky. Happy to discuss delivery options. Andy
    20221114_111652.jpg 20221114_111633.jpg 20221114_111608.jpg 20221114_111547.jpg
  2. Should have said, this engine is not suited to a road bike ......... and that should not be taken as a challenge. Ticks over at around 2000rpm, soft limiter at 11000rpm although capable of revving to 13500rpm if you want 600 mile refreshes. Andy
  3. Negotiations entered into, @El Toro @Ducbird, I’ll let you know when the deal is done. Andy
  4. @Ducbird @El Toro Viv, Terry, delighted to say, a done deal so thread can be closed thank you. Andy
  5. Thread closed :)
