950sp Or 1100 Evo Sp
Discussion in 'Ducati General Discussion' started by Simon Norton, May 21, 2023.
  1. I'm more towards the 1100evo sp as it's nearly 90kg lighter and has a tambourine for a clutch. But has anyone got a good reason to go 950sp instead?
  2. 90?!?!?!
  3. Around 20kgs if weights are wet if dry then that changes a bit.
  4. Feck wrong end of the number board. That was meant to be 30kg not 90kg, if only. This is by weights stated wet. when i looked it up.
  5. 950sp, all the way!!
  6. What made you go that way?
  7. I think the 1100 is cooler. aircooled. nice lump of torque. Wouldnt be dissapointed with the 950 tho. Small margins but the 11 is a bike ive always liked. Wouldnt buy one as i'd kill myself. Ive had 2 spermoto's and both were lethal. That 1100 would finish me off.
  8. Anyone ridden both of these machines in sp or otherwise spec for to compare the engines? I only rode the Evo sp but that was 6 yrs ago and I wouldn't call that a very good back to back ride if i go a 950 now to compare.:D
