996 996r Oem Exhausts
Discussion in '748 / 916 / 996 / 998' started by Valespark, Oct 30, 2021.
Tags:
  1. I did wonder if they came equipped with "road and race" set-up. CF & ECU as race upgrade, but alu pipes and base ECU to get past regulations.
  2. I think they did, certainly 1098R did for example.
  3. The Termignoni 50mm carbon 'not for road use' exhaust + ecu was in the catalogue and you could specify it at the time of purchase. The standard exhaust is aluminium. If you need a part number for the carbon 50mm end cans, I'm pretty sure I have an original box in the loft. Andy
  4. I was given a aluminium set when i purchased mine back in 2017.
  5. Andy to save you the bother
    Alloy ones were, RH 57310511A and LH 57410511A
    CF ones were RH 57310631A and LH 57410631A
    Same part numbers used on the 998R
  6. yup, I've got both sets :upyeah:
