Hi All, A bit of a clearout! Thought I would stick the bits on here before fleabay... All prices without P&P, and collection is possible from Crewe, Cheshire. Drop me a PM! Brembo 65mm Goldline Calipers with lines - removed from my 748 SPS, the bike was a barn find so not in great shape! £50? Wing Mirror off the 748, LHS I think, not in bad condition with just a couple of marks - £10? Ducati 749 / 999 Standard seat, lifting in a couple of places as usual but can be easily re-trimmed! £10 Ultra hard to find 749 / 999 Ducati Performance Magnetic tank bag - Bought off a member on here and hasn't been used since. Can't remember what I Paid - £SOLD? Standard 748 Air tubes - £SOLD Ducati 748 / 916 / 996 / 998 Ohlins Rear Spring - £30 Ducati 749 / 999 / 998 Carbon Belt Covers, I am keeping the centre section for the 748, so just the bits pictured - £SOLD 749R Magnesium valve cover, should fit 749 / 999 / 998, a lot of pitting due to corrosion but sandblasted and repainted, plus cant be seen when fitted - This is so light compared to the std part! £30 749 / 999 Exhaust heat shield, a bit of cracking - £10 Standard Testastretta Valve cover - £10 Brand new in box Hyperpro rear spring for 749 / 999, bought this and sold the bike before I could use it! - £70 Ducati 748 / 916 rear wheel - Poor condition, off the barn find again but I am sure these can be put right! £SOLD Ducati 748 Front end (Forks, wheel, discs, axle) ! Replacing everything so not bothered separating (I did try briefly and then gave up!) Again, this is all in poor condition - £SOLD
I'll give £120 for the front end and rear wheel if still available. PM me with your paypal or address and I can collect sunday. Cheers Lee
I can confirm that the front discs are cast iron and floating, but the front calipers are not P4\34 they are the stock 748\9** calipers, they look like 65mm spaced ones. Only 748R's had P4/24's as stock plus other later models.
You have to be wary of carrier wear in the bobbin area on those cast iron discs. Yep, 65mm Goldlines. And a LHS mirror.
Blast...I should have bought the front end then sold the discs later for a tidy profit....if I was a true capitalist pig-dog.
