Abba Superbike Stand
Discussion in 'Ducati General Discussion' started by T500, Jun 26, 2017.
  1. Anyone use a ABBA superbike stand on a Multistrada thinking of buying one
  2. Yes. Worked fine (I had the S without the centre stand). Useful as you can transfer it from bike to bike by buying adaptors
  3. Will the front wheel lift arm work with the Multi? It won't on my KTM 1190 because the bike is too tall and the suspension travel too long for the Abba stand to lift the wheels sufficiently clear of the ground.
    The 19" front wheel may be a factor but even if it were a 17" the Abba barely lifts the rear off the ground at all. Looks like its at the limit of it's lift range with taller adventure bikes.
    Not an issue for me because the 1190 has a (tall) centre stand and I have other bikes on which the lift arm works fine. But for me the whole point of the Abba is that is does the job of both front and rear paddock stands, so if the lift bar won't work you're only getting half the deal. Worth checking if this is the case with the Multi, especially it it hasn't got a centre stand.
  4. I used an Abba stand on my Multi but with a separate front stand for the front wheel. I don't see that there should be an issue using the front wheel lift arm though as the stand lifts the rear wheel well clear of the ground, maybe a couple of inches.
  5. I used it on my 916 and I used it on my old 1198. I also used the front wheel gadget, which works in a fashion but I still use ratchet straps round a scaff pole running from wall to wall for security.
